Sweet i'm listed as a Pennzoil Fanatic.....even though i don't use it and never intend too.
I guess I'll start a jack-*** list.
Unless you're changing oil in a dust storm, I fail to see how abrasive contaminant debris can make its way past a 1/2" hole in a matter of hours.quote:
.... there is probably more of a risk in leaving your oil pan open and exposed to the elements allwoing larger dirt and contaminant particles to enter the engine....
If a bug fly into the drain plug and start building a nest (or if they fly in and got stuck), then you have a lot of abrasive-contaminat in there.quote:
I sure have changed a lot!quote:
Wow Patman, you're getting rid of your issues about one per year. You now re-use funnels, don't go for the perfect drain, etc
that would probably be a bad thing. i do know a guy who will start and idle his engine for 10 seconds during an oil change to pump out the oil in the oil pump and galleys. this is probably a bad thing as well.quote:
Like others here, I jack up one side of the car, then let it drain and let it down. I repeat this a handful of times.
Okay...now how long will it be until we read about a guy who drained his oil and then drove his car up onto a set of ramps? A handful of times too?
For those of us that let the oil drain a relatively long time, I'm sure this is the reasoning behind it.quote:
Minimun 1 hour, usually overnight. I want ever last drop of old dirty oil out. My theory is the dirtiest oil is those last few drops.
