I know the 3.7 is a great engine as long as it is installed with the replaceble water pump. How is the 3.5L non turbo used in 2015 and 2016?
Agreed, but it had to be done in terms of packaging; to make it fit into the planned applications. I would have preferred a remote location; drive it off the back of a cam (it's been done before with some success). OR ... even drive it electrically (also done with success in some vehicles today). But Ford chose the internal locationIf only they hadn’t repackaged the water pump to be behind the timing cover on transverse applications we’d be talking about the Ford Cyclone engines as one of the best V6s of all time.
The 3.3L has the dual point fuel injection - looked at one in 2018 and already did then …- The 3.3L/3.5L/3.7L are the "Cyclone" series from Ford.
- There's no significant distinction (other than displacement) for an engine in the same comparable application.
- As time progressed, they had both PFI and DI applications. (I think perhaps the current 3.3L in the F150 has both?) The engine you're referencing is almost assuredly PFI.
- Overall the engine series is very reliable in N/A forms, in longitudinal applications.
- Even in transverse apps, the n/an engine is still quite reliable. (It's just uber expensive to replace the water pump due to its internal location).
This is excellent to hear. My 3.7L in my taurus has 200k on it and runs excellent. Water pump will be due any time now as its original.
My 2018 F-150 with the 3.3L had both types of injectionThe 3.3L has the dual point fuel injection - looked at one in 2018 and already did then …
