Correct. In 2012MY they introduced the 2.0L skyactiv engine as an option (rather standard on the i Touring and i Grand Touring trim levels) on the Mazda3. In 2014MY they introduced a new Mazda3 with a longer hood and part of the firewall reshaped to make room for that large header. Then all Mazda3's came with a skyactiv engine, either 2.0L or 2.5L. I wish I had the 4-2-1 header.
I'm not delighted with what I'm hearing about the new 2019 Mazda3 with a torsion beam rear suspension, no hope of a Mazdaspeed version, and a move towards 'mature' luxury NVH, interior design, and materials, away from an affordable and efficient zoomzoom driving experience. I may rush my next car purchase to buy a discounted 2018 Mazda3 touring or Fiesta ST.
My skyactiv engine heats up somewhat quickly by running rich with delayed ignition timing and high RPMs when cold. On cold days the idle at start up consumes around 1.5 gallons per hour. When warmed up idling consumes only .2 or .3 GPH. The keep the delaying ignition timing till the coolant temp exceeds 60C, on very cold days it waits till the coolant is even hotter. Average fuel economy is heavily impacted by cold starts. When running in an Atkinson cycle after warmed up using timing around 40 BTDC with a moderate load (8-12psi manifold absolute pressure), they are so efficient that they produce little waste heat, leading them to run cold in the winter, especially if one is drawing off heat to warm the cabin. On the up side I routinely get 35-40 MPG with mild hypermiling techniques and have once gone 702 miles on 13.9 gallons of gas (all highway, all hypermiling.)
