- Joined
- Sep 28, 2002
- Messages
- 39,793
Gosh I really dislike the mentality at MS more and more.
I can setup a spreadsheet in Lotus in about 5 minutes. With never reading the manual and only getting a fundamental understanding of the syntax of the formulas ..I can basically highlight from one corner of the spreadsheet to the other diagonally ..and voila~ done. All the horizonal cells will add left to right ..total at the end ..and all the columns will add top to bottom ..all with entering two formulas in two cells ..or at least it seems that easy. One based on column (ie Ax..Zx) and one based on line (2A..99A). The rest sorta figures itself out.
Now I don't have Excell ..but it appears to be the (forced upon us) spreadsheet of choice. I have an Excell editor/viewer from openoffice.org. I can enter each individual formula for each cell ..but if I "drag and drop" the formula ..it doesn't have the brains to change the parameters for that cell.
As you can imagine, this makes longer/frequent entries (like fuel economy - immediate/lifetime type configurations cumbersome.
For example, I have two columns for fuel and miles (trip odo)...that calc is easy to put in a third column for the average. Now I have to drag and drop that formula (A/B or =SUM(A/B)) to each individual cell desending. This is irritating enough ..but livable. When I want to calculate an advancing lifetime average, however, the only way I get it to work is with =SUM(A2:AXXX)/SUM(B2:BXXX) ..but when I go to the next desending cell ..I have to manually change the "2" (A2) to the next desending cell's line. Now I think that I can just use =Average(A2:Axxx)/(B2:Bxxx) ..but that won't show the difference in evolution in lifetime average. That is, the first entries may result in 19.99 mpg in C2 ..while the next desending row will have all SUM of all A's / SUM of all B's and display the resultant number.
There has got to be some simple way to make this easier. Unfortunately I have no reference material.
Thanks in advance!
Thanks in advance!
