Originally Posted By: Ken2
Originally Posted By: chevyboy14
I found out that the reason a lot of firestone tires failed was because people ran than above 10% below the max rating thus effecting the tire with to much heat and ruining the glue atleast that is what I was told ...
Wrong.
The failures were one model of a very mediocre tire from one factory...Firestone's Decatur plant, now closed. Overloading was a critical factor, plus the fact that the Explorer of that model (around model year 2000) was known by Ford to be top heavy. Recommended tire inflation pressure was 26 psi, and the combination of running low tire pressure below 26, plus overloading, plus hot weather, plus the top heavy vehicle killed people. Goodyear original equipment tires run under the same conditions did not fail at the excessive failure rate of the Decatur Firestone tires.
http://www.ce.berkeley.edu/~sanjay/REPORT_WEB_Secure.PDF
http://en.wikipedia.org/wiki/Firestone_and_Ford_tire_controversy
Allow me to add:
http://www.barrystiretech.com/fordfirestone.html
Wrong.
Allow me to add:
