How do airplanes go so fast?
Heat is the limiting factor for engine parts. High temp parts, such as high pressure turbines and augmentor ducts are often cooled with air to allow higher gas temperatures without overheating the materials. The F110 pictured previously has hollow HPT blades with holes in them to allow cooling air to pass through them.
Wasn't that the engine that was supposed to replace the PW TF30?
It did in the Tomcat F110-400, longer "augmenter" can and new scheduling in the HMU and analog engine control. Good memories from the beginning of my career at GE. After >33 years in the electronic engine control business I'm still in awe about the sheer power and mass quantity of air and compression these engines achieve. About the only thing that fascinates me more is the Saturn rocket F-1 engine turbopump.
Of course, that's cool for an RC plane, but 290Kph/180 MPH is not fast in the real aviation world (my Cessna Cardinal was flying that fast yesterday). Additionally, RC planes (for the most part) don't have to fly at high altitudes, carry a load or fly for exceptionally long distances. RC planes can have energy dense propulsion systems (battery or fuels) and be otherwise very light weight.
Our R/C Dynamic Soaring gliders have achieved 500+MPH by exploiting wind gradients created simply by wind hitting a hill.
I believe in the future it may be possible to exceed the sound barrier using wind shears at higher altitudes.
It did replace the TF30 in the F-14. It is the alternative engine for the F-16 which originally had a P&W F100.
Yeah. It was my understanding that the TF30 was really meant for the F-111. What was the problem - compressor stalls followed by the extremely wide layout of the engines?
Here is a turbine engine design question.
Since the turbine blades are stressed by both heat and centrifugal forces, what methods are used to mitigate
blade-tip-rub against the annulus?
There is "military" grade aluminum in my Ford pick up , that must be the reason it seems to go fast
But aircraft engines do use special alloys. I took an entry level materials engineering class where the professor talked a lot of about the "superalloys" that went into turbine blades. Of course the secret sauce these days is "single crystal" turbines blades that can withstand considerably higher heat. Basic efficiency is 1 - (Tambient / T). So the hotter you can get it, the more efficient it's going to be. That supposed to be what makes super cruise (going supersonic without afterburner) possible in many 5th gen aircraft. My understanding is that PW, GE, and maybe Rolls have mastered it. Others have tried and I understand that typical yield is lower.
Some of the methods that my be used singly or in combination are: single crystal alloy blades that have almost zero expansion coefficients, air flow through and over the turbine blades. and controlled air temps around the turbine's annulus.
I worked at Kaiser Aluminum back in the mid 1980's and we rolled sheet and fabricated plate for airplane applications among many other products. Even then there were some exotic alloys being produced. IIRC we had reject rates of about 90% on some special alloys. Hard to make and still test within parameters. I imagine the metals science has advanced a fair stretch in the last 35 years.
I always wondered about that. In that materials science class I took, the prof talked about the typical aluminum aircraft fuselage, which has a cross section equivalent to an aluminum beverage can. Of course an aluminum beverage can is a different alloy that's easy to turn into a can.
That was a fun class. There was a lot about strength, ductility, toughness, hardness, etc. We had a few labs where ingots of metal were stretched until they broke. Also some stuff exposed to liquid nitrogen.
I've seen that done at Wasserkuppe, Germany, it's amazing in person, difficult for the inexperienced to visually follow and sounds really neat.
However, it's not really relevant to our discussion here. The glider in question is using gravity to achieve high speeds. The skilled pilots fly in circles in an updraft.
In a much more simple version, any pilot knows high speed has always been possible in a rapid descent. Gravity is not limited by velocity and a stable falling object experiences 1G regardless of velocity. Consider that 1G of thrust in a straight down descent.
Getting a powerplant to efficiently produce sufficient discharge velocity to create adequate thrust to both overcome drag and for the wing to produce sufficient lift, for sustained high speed flight is not an easy task. In fact, it took 50 years to develop into something workable.
There's still terminal velocity which will limit the speed due to aerodynamics of the falling body.
Sorry hot combustion is not allowed anymore. Too much NoX, can have turbine pollution can we.
As mentioned above, high temperatures can be achieved other ways. Compressing the air via multiple stages is one way. It's terribly inefficient and energy intensive. Electrically heating the air into a superheated plasma is another way. The Chinese have been experimenting with this. It's also exceptionally energy intensive. Will require amazing batteries :)
https://asiatimes.com/2020/05/chinese-researchers-create-prototype-plasma-jet-engine/
https://www.theengineer.co.uk/plasma-jet-microwave-wuhan/
