How cold would be considered safe for a 10w-30 in an ohc engine? My cam in block jeep says down to 0f but it's antiquated. Got gallons of synthetic I'd like to use up in the fjcruiser.
Oil has gotten better since your engine was made, so I’d assume it’s even safer at 0F now. I ran 10w30 in the winter in Michigan years ago and didn’t notice any issues.How cold would be considered safe for a 10w-30 in an ohc engine? My cam in block jeep says down to 0f but it's antiquated. Got gallons of synthetic I'd like to use up in the fjcruiser.
That's my concernHad a 06 Toyota 4.0L run 10w30 to 0F -15 F she start to really rattle .
That's my concern
There’s no problem in your climate with 10w30.How cold would be considered safe for a 10w-30 in an ohc engine? My cam in block jeep says down to 0f but it's antiquated. Got gallons of synthetic I'd like to use up in the fjcruiser.
Your engine operates at a somewhat different and higher heat level than 0 F. Plus there's all the stuff about parking away from the prevailing wind direction, under some kind of roof instead of in the open etc. And then there's the pour point of the oil. 3 C / 5 F above the temperature at which a sample of oil shows no movement when held horizontally for 5 seconds. Do you expect temperatures in Cali to reach -39 C or -38.2 F even up in the mountains?Was looking at some oil range charts earlier this week. It noted 10-30 OK down to 0F. For a margin of safety I would not personally feel comfortable below 10F. I placed some 10-30 in a freezer recently and it was a bit thick at around 0F.
Pour Point, °C, ASTM D97 | -39 |
17F I'd hate to tell ya ain't coldI run it year round in central California. It gets down to 17F in January. I think film strength is more important than having the oil thin enough to get moving. No matter how fast a thin oil can flow, a good film strength is already there.
We were in big bear last weekend and it was 14F!I’m also in SoCal, the coldest i experienced w 10w30 was years ago in Big Bear where temps reached a low of 25 degrees. I had a Chevy S10 (v6) at the time, it started up and ran like normal. Your FJ will be fine w 10w30 in SoCal
If you are anywhere in Cali that goes to -25 F or lower never mind the -30 or lower pour points of even dollar store engine oils ..We were in big bear last weekend and it was 14F!
