Originally Posted By: LeakySeals
1/2 qt over should be OK, a qt. over not good, I'd drain some. Simply put, too much oil can "foam" causing tiny air bubbles, and air bubbles don't lubricate very well. The easiest way to get some oil out is remove the filter and dump the oil out, repeat if necessary. Use caution and check the filter for leaks if you use this method.
Exactly what happened when I was 18. I checked and added 1qt of oil on a hill like a fool. Driving on the highway I felt the engine lose power and a strange "sloshing" sound. I Pull over, its foamed up! Unscrewed the filter, let some oil out, screwed it back, drove away. Problem solved! Sorry green people, we didn't think about it back then.
I like that filter idea. Would be nice if I could do just a regular oil change on it but for now that will do. Might go to Walmart and pick up a ST oil filter, it is the black can, from what I hear they are decent, not the best but priced right and if it works and I got the filter off then I got $3 soo...
