House passes bill to make Daylight Saving Time permanent
Kids wait for the bus in the dark already. This will be nothing new. I did as a kid in the North. My kids did here in the South.
The proper question is why does the federal government have any say in the time anyway. Its a clear over-reach they started in 1918 due to "war". Just one more power grab during war they never gave up.
This is absolutely the wrong way to think about the matter. I am more against government overreach than most, but time schemes need to be uniform to work. They need to be governed. They maybe even need to be enforced. I don’t think this libertarian question has merit.
I have the perfect high-tech BITOG-inspired solution ...
Why don't we develop a oil-pressure driven, variable drive system for clocks? It could "advance" the clocks (at a rate of 10 minutes per month) for six months, and then "retard" the clocks for 6 months (at a rate of 10 minutes per month) .... We can call it "VCT" (variable clock timing) !!!
Of course, it would be viscosity dependent; only accurate with 0w-20 "fully synthetic" oil ... 😜
P.S. ... how long before AI grabs this idea and runs with it?
Not sure how accurate this map is, but here it is anyway... Michigan is screwed. :)
There is nothing in the constitution giving the federal government control over time. They utilize the contorted "commerce clause" to usurp this power, which is really inaccurate because it says they can regulate commerce not time. If the states wanted to do there own thing they would be entitled. I will defer to our founders who were experts on such things.
The United States has 4 time zones and 9 if you count the territories so its already not standard. There are 24 time zones in the world. Changing it randomly back and forth twice a year is simply less uniform.
And just as an FYI, I work for a German company and have already traded emails with them several times today. I start early. Easy peezy.
If they can change the time so I'm not going to work looking at the sun and coming back home looking at the sun, that'll be great.
We do have a little bit shorter time between sunrise and sunset in the summer than they do up north.
But we do get dark here (Southeast Florida) at 6 PM here in the winter around the end of December.
And in Western New York, we get dark around 4:30 at the end of December. Winter daylight time get much shorter, the farther north you go!
Which is why complaints of kids getting hit by school busses on dark mornings are just inflammatory gibberish. Certain parts of the globe get more daylight than others, full stop.
What do they do near the poles? No school busses because it's never light long enough?? Give me a break.....
We have the technology -- it's called headlights and good parenting (my mom once reamed me for playing in a snowy street while waiting for a bus. I still have scars from her tongue lashing.....)
States and territories apparently already have the ability to adopt DST or not.
Hawaii and most of Arizona do not observe DST, nor do most US territories including Puerto Rico and the USVI.
Indiana did not use DST statewide until 2006.
  • Like
Reactions: D60
Again, this is why a half hour is THE solution. Equal dissatisfaction on both sides.
It is not a solution. You posit that there are two sides here: those who advocate standard time, and those who advocate daylight savings time. The latter group wants standard time for one portion of the year and daylight saving time the remainder. The opposite group wants standard time all year. Moving the clock to the middle of the two times is mathematically incorrect. Those in favor of DST, if they were equal in size to the ST group, would only be entitled to move the time setting 15 minutes, since essentially three quarters of the people want Standard time mathematically. The “sides” are not represented by your compromise. I could illustrate with an oil mixing analogy, if that helps.
