Hot deals on oil and a question ?
michigan
Aco hardware has service pro brand semi-synthetic oil on sale for $1.49 / quart. I called customer service and the local distributor and know body knows much.
Who makes this stuff ?
I also got a postcard from advance auto parts with pp for $17.99/ gallon and rotella t for $19.99. If you buy a gallon you get free 12 ounce shell v-power fuel injector cleaner.
SERVICE PRO ® PREMIUM SYNTHETIC BLEND MOTOR OILS
Manufactured with highly refined virgin base oils and licensed additive systems
Association of Independent Oil Distributors • www.service-pro.com • P.O. Box 1861 • Montrose, CO 81402 USA
Updated: 09/09 SPWNSYNB
DESCRIPTION: SERVICE PRO ® Premium Synthetic Blend Motor Oils are superior-quality, high detergent automotive
engine oils specially formulated to meet the stringent lubrication requirements of today’s engines. A
unique blend of synthetic and high viscosity index mineral oils combine with a carefully selected additive
package to provide maximum protection against wear, rust, corrosion, oxidative thickening, acid formation,
sludge and varnish deposits.
SERVICE PRO ® Premium Synthetic Blend Motor Oils meet or exceed the requirements of MIL-1-46152E,
Ford WSSM2C153-H and WSS-M2C930-A (SAE 5W-20) and WSS-M2C929-A (SAE 5w30) Meets
DaimlerChrysler DC MS10797 (SAE5W-20), DC MS10796 (SAE 5w30), DC MS10798 (SAE 10w30)
specifications and engine test requirements of DC MS6395.
Meets API Service Category SM, SL and SJ, complies with ILSAC GF-4 (5W20, 5W30 & 10W30)
requirements. Meets Honda Service Fill Specifications, GM 6094M Specification (SAE 5W-20, SAE 5W30
and SAE 10W30) and Toyota.
· Provides outstanding thermal and oxidation stability
· Helps protect emissions system
· Minimized rust and corrosion
· Outstanding low temperature pour point
· ILSAC GF-4 Energy Conserving
SAE Grade 5W20 5W30 10W30
Viscosity
@40 Deg. C, cSt 47.5 60.9 66.4
@100 Deg. C, cSt 8.2 10.4 10.5
Viscosity Index 146 160 146
API Gravity 32.5 33.6 31.1
Sp. Gravity 0.8618 0.8560 0.8692
Pounds per gallon 7.19 7.14 7.24
Flash, COC, °F 405 405 405
Pour Pt., °F -40 -40 -35
API Performance SM SM SM
Type "service pro" up in the search should yield many threads but i suspect it's a good fluid any API SM will work for 5,000 no problems,good price grab some up.
I found the answer on a msds search. It is made by warren oil. The large bulk containers look just like coastal too. If you use supertech , i am sure it is the same thing.
Coastal is made by Warren Unilube. Some Supertech oils are made by Warren Performance Products / Warren Distribution.
Either way, a semi-syn SM oil for a buck fifty is an awesome deal.
It looks like they are made by warrren unilube / coastal/lubrigard/autoguard. same junk.
good oil , very cheap prices.
