When I sampled this, the fluid was very dark. Does the flashpoint seem a little low to anyone? I didn't dump the fluid, but plan on doing a partial swap with Mola's Z1 replacement and then another partial swap at 15000 miles again with Mola's Z1 replacement.
Code:
Honda Odyssey
3.5L V-6
Vehicle miles: 7,693
Miles on oil : 7,693
Life of oil : 8 months
Lab: Blackstone
This is the factory ATF your Honda came equipped with, and it looks pretty good.
WE didn’t find anything too far out of line. Wear metals are perhaps high for
an oil run less than 7700 miles (averages are based on 15,500 miles), but
that’s due to wear in of new parts. Everything should improve with the next
sample, which we think you can run longer than this. No contaminants were
present, and no insolubles were present. If this oil hasn’t been changed, it
can stay in place a little longer. Otherwise, run your next fill 10K-12K
before sampling.
Date 12/06/06
MI on oil 7693 Universal Average
Unit MI 7693
Aluminum 24 25
Chromium 1 1
Iron 58 70
Copper 10 17
Lead 1 4
Tin 0 1
Moly 0 1
Nickel 0 0
Manganese 0 1
Silver 0 0
Titanium 0 0
Potassium 1 1
Boron 242 199
Silicon 8 13
Sodium 12 7
Calcium 361 366
Magnesium 215 157
Phosph 4 76
Zinc 326 263
Barium 9 4
Sub Viscosity @ 210 = 46.9
Should be 42-51
Flashpoint = 340
Should be >335
Water =
Should be
Insolubles = 0.0
Should be
Code:
Honda Odyssey
3.5L V-6
Lab: Blackstone
before sampling.
Date 12/06/06
Unit MI 7693
Aluminum 24 25
Chromium 1 1
Iron 58 70
Copper 10 17
Lead 1 4
Tin 0 1
Moly 0 1
Nickel 0 0
Manganese 0 1
Silver 0 0
Titanium 0 0
Potassium 1 1
Boron 242 199
Silicon 8 13
Sodium 12 7
Calcium 361 366
Magnesium 215 157
Phosph 4 76
Zinc 326 263
Barium 9 4
Should be 42-51
Flashpoint = 340
Should be >335
Water =
Should be
Insolubles = 0.0
Should be
