Honda V-TEC Oil Check it out
quote:
Originally posted by JohnBrowning:
P.S. I just like people keeping an open mind!
100% agree!
I've found the 15w40's to work great in the many various applications I've tried them in and that's why I recommend them so much.
With that said, I fully accept that these aren't a good choice for many out there, and that other lubes are more ideal. You'll rarely if ever see me knock someone elses recommendation unless I've had a bad experience with it that relates to the application in question...I'll just say that I've actually used something else with great results.
What ticks me off so much is when a few select people on here will completely denounce my findings in the field and replace my experience with what they want to believe. It's just plain arrogance...the unwillingness to accept that something else might actually do a great job.
Jelly I agree with your statement 100% it is more in line with what I wanted to communicate!!
I will never argue that 5W20 can not do a good job in the applications that recomend it. Now does it do the best job???
I just do not understand why people refuse to belive excelent research put out buy professional secietys and additive formulators! Why would anyone want an oil that only provided the bare minimum protection? Even if you have 20 excellent UOA with it what happens when you need just a little bit more protection then it can provide?
They even selectively ignore reports from within the industry about timeing chain wear etc......
(By Jelly)What ticks me off so much is when a few select people on here will completely denounce my findings in the field and replace my experience with what they want to believe. It's just plain arrogance...the unwillingness to accept that something else might actually do a great job.
Very well put. I'll use what works better for me and others can use what works better for them. I don't mind that at all. When I changed from a 10w30 to a 15w40 I would have been pleased with equal wear and mpg. But when I got less wear and an increased mpg some became rather 'bent' by it. Live and let live...........
Buster - Quite amazing that you mention Lubes N greases rec 10W40 a viscosity most thought dead. Just a few mins ago I was looking at the Castrol Australia site checking on the Magnatec 10W40 now updated to SM spec. May I suggest all of you check this link and tell me what you think of the graph showing initial wear. Click on Magnatec microsite, then Castrol Maganatec at the bottom then right arrow to page 3. The graph is TLA competitor testing and 10W40's from various vendors do well supposedly. The 0W40 performs worst by far (in this instance). What do you guys read into any of this? http://www.castrol.com/castrol/castrolhomepage.do?categoryId=3000
Well it seems like every were that the evil CAFE does not exsist companys prefer a 40Wt or thicker for the most part. Go figure!
This is not about weather or not a thin oil can turn in a decent UOA! It goes to propaganda!It is more about paradignms(sp) then anything else. We all know that HTHS is the most important factor for preventing wear long term not some silly API viscosity rateing!
Easy there, fella! These are not representations that 20 weight provides better protection than 30 weight viscocities. I interpret what most people are trying to evaluate with UOA presentations here is whether 20 weight provides an adequate MPG vs. wear compromise. Consider the question from a vantage point similar to what Gary postulated above - what if you do get better mileage and acceptabile wear with a thinner oil? There's always going to be wear, so the question/bet/risk is, can the consumer expect to make it to what they define the end of their vehicle's useful life using a thinner viscosity oil? As Buster said, so far no complaints of untimely catastrophic failure yet, so the jury is still out.
Actually, I believe the argument can be made that most oil recommendations are political, cultural and economic as well as regional compromises. For example, European vehicle oil drain recommendations are influenced by conservation and cost considerations compared to US drain recommendations. European oil recommendations typically require higher (read, bigger $$) quality standards. Because US consumers expect oil to be cheap here, I don't think we will see manufacturers specifying more expensive quality oils required for 18K drains for the US, though they could. Manufacturers like Honda believe that the average US consumer values low cost and higher MPG more that long drain and lowest wear possible, which is completely different than the typical BITOG patron profile. So the oil recommendation is tailored for the US customer accordingly, with shorter drains with cheaper oil but thinner "fuel and $$ saving" viscosity emphasized.
quote:
~SNIP~
When ever anyone onthis recomends exactly what the manufacture recomends outside the USA you get all kinds of flames! "Well that is not what my owners manual says." etc!!!!
~SNIP~
Because of the difference in typical climate between the US and Malaysia, I can accept that the thicker viscosity recommendation here truly is temperature and protection based. For regions with temps like Malaysia where climate never encounters freezing temps, a climate where temps rarely dip below 80F, most manuals recommend or permit a thicker viscosity than for their "typical" regions. So if the flamers say that's not what their manual says, the concern isn't whether thinner is better. Again, the question is how thin is too thin, hence the citings of UOAs.
You are right that for some engines and applications 20W is too thin, but I'm not sure that that 20W is always too thin.
[ January 09, 2005, 12:51 PM: Message edited by: darryld13 ]
It's an old article. I saw it a couple of years ago and never bothered to post or link to it. It isn't an article written yesterday that contains a hidden smoking gun.
Copyright 2001? SJ spec? D17 engines? The clues are there if you look for them. But that said, I first saw it in 2003.
From the website :
"" I myself have since switched from Shell lubricants to Honda's "Engine Oil" on my Integra. With Honda's "Engine Oil", the engine now seems much quieter and smoother at idle, with a clear feeling of "lightness" when asked to rev to high rpms (which is probably due to the lighter 40 weight as compared to Shell Helix Plus which has a weight rating of 50). The engine note is much more race-like with a much clearer distinct change in note at the VTEC changover point. ""
That there is something a analysis report will not show , or at least last time I saw a report
If he liked the lighter 40wt , he most certainly would like the 10.5 cSt Mobil 0w-30R or Synergyn 3w-30 at 9k rpm . Maybe he should try that 10w30 in the link also ?
Anyway my opinion is when an knowledgable owner speaks about actually feeling the difference in power when using a lighter oil that's the trumph card .
to each his own i suppose, im perfectly happy using 5w-20 in my civic, i know it will live a long happy life with it. these 5w-20 topics have been beaten to death.. i think the dead horse is flat as a pancake now..
