correct, thank.
Wilbur, I would also suggest a pipe to extend the breaker bar length. I’m reading all the suggestions to hopefully improve next time.
And a really good breaker bar. People break theirs all the time getting these things off.
Another word of advice, the tool that you can buy to hold the pulley..... If you use it, have someone hold it in the pulley. I had one slip once and broke one of the hex sides out of the crank pulley.
Seriously, if you don't have a super beefy impact, the easiest way is the starter bump. Spin the crank around to where the breaker bar rests on the floor with the control arm directly above and blip the starter. Might take more than once but it will go. The bar will fly up and hit the control arm, but shouldn't hurt anything in the process. Its good to disable the ignition (Pull the connectors from the coils), but you don't 100% have to. If you have a model like my TL you have to quickly hit the start and back all the way off or it will continue cranking (Its a '1 touch' start or whatever they call it)
If you choose to heat it, I would go ahead and absolutely replace the crank seal. Don't forget that the oil pump is sitting right there on that end of the crankshaft as well, so don't go crazy with the heat. There shouldn't be anything in the pump that will get too hot...but I'm a little leary of that.
All this is why I suggest you break the bolt loose days before you want to do the job. That bolt can be a right pain in the arse and it can take a lot of your motivation out of you and get you frustrated to where the rest of the job is harder than it needs to be.
