I'll take my belts over this any day of the week.......
Also, as has been mentioned, the job isn’t all that bad, at least on the pickups. The worst part for me is getting the new accessory drive belt on. (-:
I suspect I just made you have a PTSD moment Trav.
I used the "starter method" on a friend's Mitsu Lancer a few years ago, after we'd tried everything else. Scared the heck out of me, but worked great.As mentioned above, the crank bolt is the tricky part. I used the 'starter method' on my 06 Pilot with success. I've never used one, but I've read that the hot setup is using a special socket for getting it loose e.g. Lisle 77080.
On a transverse DOHC V6, the timing chain is long and complex, and is typically not designed for easy replacement. As well, most timing-chain-equipped engines are of the interference sort, whereas a lot of TB engines are non-interference. I'd far rather do a scheduled timing belt change every few years than have a timing chain fail.I was fully aware when I bought the car brand new.
Thank you
I've never had a Honda so I've never changed a timing belt on one. I done several Ford timing belts and always use a 1/2" drive electric impact from Harbor Freight for removing the crank bolt on them. Doesn't take but a few seconds to break them loose. Harbor Freight often runs their 1/2" impact for under $50. and if I recall correctly they're rated at 210 ft. lbs. or torque.
As I said I never owned or worked on a Honda. I was just trying to help out the OP'er without breaking the bank. I've read on forums of lots of people using the starter or a long cheater bars on their Ford crank bolt. I don't think I've ever had to hammer at one for more than 5-10 seconds with my impact. Ever tried putting anti seize on the crank bolt to see if it makes it easier the next time out?Honda crank bolts give more trouble than any other make, I use a Proto 3/4" impact @ 150 psi to break them loose which is well above 1000 ft. lbs......If you really want to rate Impacts that way. It's all about the Hammer/Anvil Size/Weight & that's why Weighted Sockets "can" work with a 1/2" drive impact.
So what's the deal with Honda, are there absolutely no aftermarket parts that are good enough for it? Must one use only Aisin Mitsuboshi or whatever including the crappy OE tensioner? Is aftermarket really that bad? ...
