Honda PS - is there a full synthetic?
I started using the ATF+4 in the power steering units at out place since the price has dropped so dramatically in the past few months. Wouldn't venture a guess as to compatibility with your Honda, though.
There seems to be some seal compatibility issues, which I have not personally seen yet, but time will tell. I hope to determine this one way or the other in both the steering and transmissions over the next year or so, at least as far as our equipment is concerned (a wide range of Chrysler products of all ages).
It would be nice to stock just one fluid for all that.
All the Jeep info I've seen is NOT to use ATF+4 in a PS system. And to use MS-5391 approved PSF instead.
Valvoline Synpower or Redline PSF, I'd look into one of those.
Michael Polutta -
While I cannot tell you if Honda Genuine PS fluid is semi-syn or not, one thing is for certain: flush and refill with Honda Genuine PS fluid every several years and your power steering pump +rack will thank you for that, giving you long service life and reliability.
I just did it to my dad's 7th gen civic last weekend (with 100,000kms on the clock, AutoRx'ed the PS part) with genuine Honda PS fluid (I took 3 using turkey baster method) and it is now running smoothly...
Do not substitute with non-Honda spec'ed PS fluid for there is a seal inside your steering rack that once come in contact with non-Honda PS fluid (such as Dexron, etc.), it will swell and cause all kinds of leaks.
Quest - Great minds...
I am in the baster-process after several hundred miles with ARX in our PS system. 3 drain/fills so far, and the fluid is just now starting to look clearer. Methinks the ARX has done some cleaning! This was the factory fill, 48K on the odometer and 3 years. I'm thinking about swapping out the factory PS cooler for a stouter unit.
The driver for my question is simply to have a fluid that can take higher temps more easily. I fully understand about non-Honda-spec fluid. I have not found a full-syn Honda-spec yet, and I did search...
FYI - there is a thread on odyclub.com that measured PS temps, and the result is that PS temps are strictly related to engine RPM, not load. The reason you need a stouter PS cooler when towing is not due to the weight, it is because you will spend less time in "lockup", more time at higher RPM. We don't tow, but I want this vehicle to last a long time. Any simple (and fun) thing I can do - like upgrading the PS cooler - I am likely to do. (Gotta shore up the ATF filtration first...)
PSF temps being rpm-based makes sense to me.
It's a pump, it's going to make heat when it makes pressure, and it's going to make more pressure with more rpms.
quote:
Originally posted by acewiza:
What info would that be? Can you provide a link or quote?
yep, I can do both.
www.wjjeeps.com/service/maintenance_wj.htm#OTHER
quote:
Mopar®P/N 04883077 Hydraulic fluid / Power steering fluid (MS5931)
MS5931 IS THE ONLY FLUID THAT CAN BE USED FOR THE POWER STEERING SYSTEM. NO EXCEPTIONS!
Important note:
The factory fill power steering fluid for all 1999-2004 Grand Cherokees is a unique fluid, MS5931. ATF+4 (MS9602) should not be mixed or used as a “topping off” fluid on the Grand Cherokee WJ. All WJ models should be serviced using ONLY the special MS5931 fluid. ATF+4 is NOT an approved Power Steering Fluid and should never be used under any circumstances. Note that all fluids will darken in color with usage and fluid color is no longer an indication of fluid condition.
Amendment - I just bought a bottle of NAPA-brand Honda-spec PS fluid. The back of the bottle says "petroleum oil." Guess it isn't semi-syn - at least the NAPA brand is not.
Use Lubegard. They sell a PSF additive that converts ATF or regular PSF to Honda Power Steering Fluid. So, grab your Amsoil/Redline/Mobil1/....ATF and add the lubegard if you want a full synthetic PSF.
From what I remember, its not a seal issue. It a fluid foaming and PS beating the snot out of the fluid issue.
I turkety bastered my way through a bottle of Honda Genuine. Took about 3 pull and fills to kill the bottle. Way to scared to play with anything else in the power steering box.
IMO, bag the baster. It's SO EASY to pull a hose and insert a funnel. 99% change in one shot. I pull the Resevior OUT / Pump IN hose and insert funnel. I put a piece of aluminum foil over the hole in the resevior and disconnect the dist spark. Crank the engine as you pour PS fluid into the funnel. Drain the resevior and do it again until you have a resevior of clean fluid and then top-off.
I ran into the webpage of one OEM supplyer of Honda PS fluid (forgot the name) and they had a spec sheet on normal vs Honda formula. Honda PS fluid is thicker and contains some anti-wear additives like Ca, P, Zn, etc. Molakule agreed in one of my previous post on the same topic too. I am not sure about the "quality" of base oil though.
