Originally Posted By: Audi Junkie
Audi does not require special fluid like the oem CHF-11S. In fact it works better on Mobil 1 ATF. Many guys with CHF systems use the thicker and better additized ATF with perfect results. In fact, the CHF looks great on paper, but is a disaster at 6cSt. Heat is outta control in the system and goes runaway as the pump shreads and scalds the seals.
Junkie, you've been posting this many times on this forum and audiworld. I think you are posting junk. Audi PS systems are very sensitive and I wouldn't play. Mobil 1 ATF is too thick for the winter, and if a 'weak' additive package concerns you, flush it often. I flush mine twice a year with 11S, during my oil change // 13 years and no leaks so far. Grab yourkock and letitrock.
