The Honda OLM system is programmed into the PCM and considers such things as number of crankshaft revolutions, miles, engine temp, etc. It is a basic program and for the average car will have 0% oil life remaining from somewhere between 5-7K.
Once again: Using a quality oil at the factory recommended interval will probably cause no harm. If you feel uncomfortable with that then a UOA would be in order and would probably show this to be true. Honda engines are some of the best around. Basic maintenance on the engine will make it last far longer than the car itself.
