What is the recommended interval for replacing spark plugs in a 2016 Honda Odyssey?
Look in the owners manual or the internet. Or are you asking if you should go shorter. My guess is that your car calls for replacement at 105,000 miles.What is the recommended interval for replacing spark plugs in a 2016 Honda Odyssey?
Plugs wont seize even after 100,000 miles. If that is a concern, use anti-seize on the treads.I take spark plugs out every 20k miles or so not only to inspect them but also to prevent the threads from seizing.
Do NOT put Anti-seize on NGK plugs.Plugs wont seize even after 100,000 miles. If that is a concern, use anti-seize on the treads.
?code 4
More likely to mess up the threads messing with then all them time rather than just letting them go their whole service life.I take spark plugs out every 20k miles or so not only to inspect them but also to prevent the threads from seizing.
Newer Hondas display a subcode on the maintenance minder. See below.Change them when code 4 pops up on the minder
Not recommended. Once a plug has been installed and torqued, the crush washer is “crushed” and it really shouldn’t be crushed again. I only change plugs at the manufacturers recommended intervals.I take spark plugs out every 20k miles or so not only to inspect them but also to prevent the threads from seizing.
Never had a problem installing the same spark plugs up to three times. On the other hand, I have seen seized spark plugs in other people's cars. I would not feel comfortable using soark plugs for over 30k mikes without inspection. If I were to mind reinstalling them I would replace them. You can do what you want.Not recommended. Once a plug has been installed and torqued, the crush washer is “crushed” and it really shouldn’t be crushed again. I only change plugs at the manufacturers recommended intervals.
I suppose you believe the same story on oil filters and their gaskets?Not recommended. Once a plug has been installed and torqued, the crush washer is “crushed” and it really shouldn’t be crushed again. I only change plugs at the manufacturers recommended intervals.
Shoot I’m on 5th oil change on Odyssey crush washer. Not a drop. It’s finnnnneeeeeeeeeNot recommended. Once a plug has been installed and torqued, the crush washer is “crushed” and it really shouldn’t be crushed again. I only change plugs at the manufacturers recommended intervals.
