Honda V6 VCM, again.
Same. If you think Nissan's are high maintenance, hold your beer.
I think the Odyssey didn't get VCM3 until the next generation.
Not at all an odyssey expert so likely missed that.
Is the 2016 ody an "earth dreams" v6?
I don't think Honda is the same Honda ever since they started putting in turbo. Their strength was always the higher rpm engine with way over build internals, like a 140 hp engine that would be fine running up to 8psi boost with stock internal, and up to 300hp if tuned well.
I think a lot of the "why don't they fix them" problem is emission testing after release and the credit they have to cough up if they detune them for durability in some corner cases. Extended warranty is likely the cheapest way out that still makes customers happy. My Toyota and Honda / Acura both had some of those and they cover some of the stuff up to 150K and 10 years. I mean, what more do you want from a warranty?
At the moment it almost seems like Mazda got lucky because they know they are the small guy who can't afford to be too aggressive so they just stay old school, and end up being the more proven design. I don't mind that, that's kind of what I want in a boring commuter anyways.
We’re talking about a NA V6 with cylinder deactivation; this engine design launched long before the 1.5T.
I THINK the plugs were replaced at some time. The front 3 looked fine. What I didn't understand was the new coils.
Anyways, I have ordered the muzzler.
I have to wonder why Honda hasn't properly addressed the VCM issue. Or maybe I'm missing something?
Because Honda doesn't care about their customers. No automaker does. People hate on GM with the AFM/DFM issues but Honda has the same problems and just like GM shoves their head in the sand given that most of the vehicles make it out of warranty.
That makes sense, but I think there's a range. Or whatever. But they work; that much I can tell you. Hopefully it's not too late for this Oddy. It's really nice!
VCM Tuner II
The VCM Tuner II in my Pilot shows a bit differently than the S-VCM I had prior. They both hold a 165F from ECT1 which is below the threshold for VCM to engage. The VCM Tuner II is a larger "box" and has inertia/vibration sensors or something. When I sit at a traffic light now after like 30 seconds the ECT1 shows actual temperature until you step on the gas and move. S-VCM just stayed at 165F which was OK. I didn't get a picture of the higher temps. I only get the Pilot if it needs gas or on trips normally.
Some people have no VCM issues as they don't meet the parameters. It needs temperature, light throttle, and whatever else. If all around town then it won't engage. If heavier foot or versions on highway than it won't. When I didn't have S-VCM I found I could get VCM to engage more by very conservative driving more then even leaving it on cruise control.
Thanks.
So 2017 was the "earth dreams" year for the Ridgeline and Odyssey.
The front 3 are easy to reach, so often people stretch out the back ones.
Id guess the bad coils are VCM coils on the ugly plugs?
None of the cylinder deactivation schemes are without issues, and VCM 3 is an improvement over 2.
From what I understand VCM 3 eliminated the 4 cylinder mode and improved the timing of the transition to (or close to BDC) eliminate the vacuum that could pull oil past rings.
You may want to try running something ester based - Id bet those VCM slugs are filled with crud.
Thanks.
This is the chart from dashboard light. It matches everything I found anecdotally on owner forums also - that every early iteration of VCM 1, 2 and 3 all had issues early that seemed to improve over the years until the next iteration. Notice the spikes on the Pilot - for each early VCM iteration.
What Honda changed who knows. They tend to keep this sort of stuff to themselves.
https://www.dashboard-light.com/vehicles/Honda_Pilot.html
I don't know about any bad coils, I just believe all 6 were replaced. Possible wallet flush.
I am pretty sure there has been zero DIY work done on this Oddy. All dealer or shop.
2016 was VCM2 IIRC - 3, 4 and 6 cylinder activation. I thought that was better than VCM 3. Maybe I have it backwards?
If they are original plugs at 127K, then honestly its hard to fault the engine. Plugs are a wear item.
Yep.
90K miles max on spark plugs.
For a new Honduh owner where do I get educated on VCM?
Is Piloteers the best resource or is there a good FAQ or Wiki or something?
Yep.
That'd be safe.
Just took mine out at 101 and they were beautiful - should have taken picts but I was preoccupied with the being under the valve covers.
I was on the hunt for oil fouling like Jeffs pict but didnt see it.
As it was I was over on time but under on miles to get the belt notification - but decided to do the belt at 8.5 years. I expect I'll get the belt notice from the MM at the end of this OCI.
If you perform a service before the subcode appears, you are supposed to reset the service item. On older models this requires a scan tool; on newer models it can be done via the dash or radio.
I was just going to clear it out when it arrived - no doubt at the end of this OCI It'll pop.
Since the 2017 MM doesn't actually track time, but only miles, this part of it is off the factory spec by a year and half already, but a few K under the miles.
The MM also doesn't take into account mountain service for VTM differential so it's off there as well. (Odysseys dont have this problem which is a bummer as an AWD Odyssey would be phat)
I keep a completely separate manual paper log for every vehicle.
You may need a decoder wheel to discern what Im actually writing - but it's there.
Yesterday my neighbor's daughter was over to her folks for a BBQ with her 2 children and texted me about her 2016 Odyssey EX-L, 127K, running rough on the freeway.
Threw a P0303 trouble code. This morning I started to pull #3 plug, but could not get the coil to budge. I was afraid to use a pry bar, as this is not my car. It was stuck! I beat myself up pretty good, but could not get it to budge. Took it over to a local shop, Scotty's Automotive. Here's #3 plug:
I am not sure if the plugs have ever been done. But it looked like the coils were replaced! Anyways, I asked them to replace all 6; it was $457 all in. And yes, the 1-2-3 bank were all fouled.
I will likely order the VCMTuner II tomorrow morning. I love Hondas, but IMO this is a huge black eye.
You do know there was a class action lawsuit over this engine and its oil consumption. My daughter’s 2012 Odyssey was included. Honda’s super aggressive attorneys fought it tooth and nail. It turns out, their cylinder deactivation scheme, when activated for long periods (such as steady state highway driving), causes differential cooling in the deactivated cylinders thereby allowing oil to get past the rings and soil the plugs on its way out the pipe. Extreme examples include outright seizure for those who don’t bother to check oil levels frequently. This was the origin of the adoption of the ridiculous dealer mandated “standard” of 1 quart per 1000 miles being “normal” consumption. If you have a five quart sump and a 7500 mile OCI, guess what happens? Honda got off with no acceptance of blame and giving owners of these engines an extended warranty which was pretty worthless. Many, many diehard Honda fanboys swore them off. Honda could have cared less as long as they protected their bottom line. Do some research. You will find the court documents. They are enlightening to say the least.
Honda engines were the gold standard for reliability. I have the VCM Tuner II and will install it this week. Hopefully the engine is not yet damaged. I did an oil change a month or so ago, and the level was too low. I guess we'll see.
I should also look into the TSB for a piston ring replacement.
All this talk here over the VCM issues and the need for muzzlers. I have a 2008 VCMII with 126 k miles. Never had ANY issues with this car. Just routine maintenance and wear items replacement. Not a single repair. I keep it bc its so reliable and does not collect info on me. Looks great, super smooth and pulls strong. I service the PCV valve religiously and do 4-5k oci with Mobil 5-30 oil. Gets 28-30 mpg on the interstate. What more could one ask for?
The VCM Tuner II and Valvoline Restore and Protect may not need ring replacement after a pretty short time (unless damage done). If extended warranty or actual recall will cover rings then maybe it's an option.
