So I was going camping this weekend. I have a lowly '95 Mitsu Montero pulling a tent trailer and I was following my friend with his '02 Honda Odyssey pulling a tent trailer. We were cruising up Highway 5 goin' 65mph with 87deg ambient temperature when some nice black smoke started pouring out from his minivan. We pulled over and sure enough the ATF had spilled out of the transmission dip stick. It smelled all burned. And my friend said that the transmission had started slipping. After it cooled down everything worked OK and we made it to our destination and home again. (travelling a bit slower).
I know that this is a typical scenario when transmission fluid overheats, but I have a couple questions.
1. Why does the fluid get so hot? What generates the heat? I assume the Odyssey has a lock-up torque converter, so what process in the transmission generates heat when you are cruising on the highway?
2. How hot does the fluid actually get in this situation? Is it actually boiling? Or what causes this extreme expansion of the fluid which causes it to come out of the dip stick.
And yes, he is getting his transmission fluid flushed today. He had a transmission fluid cooler installed by AAMCO ($300 vs the $600 dealer cooler - might have been a false savings). Anyone try the AMSOIL ATF in their Odyssey?
