EQUIPMENT MAKE: Honda
EQUIPMENT MODEL: 2.4L 4-cyl (Currently 50K miles)
FUEL TYPE: Gasoline (Unleaded)
OIL USE INTERVAL: 10,000 Miles
OIL TYPE & GRADE: Mobil 1 5W30 and T&SUV (60/40 mix)
MAKE-UP OIL ADDED: 0 qts
GEORGE: The engine result of your mixing and matching of oils is a product viscosity that we would expect from a 5w30 or light, 10w30. We can't argue about the wear results it has left you with. Universal averages show typical wear metals for an oil from this type of engine after about 6,260 miles run on the oil. Your oil was in use far longer, and we found wear generally, at better than average levels and in the correct balance to show normal mechanical parts inside. Air and oil filtration appear normal. The TBN was 2.4, still okay. Try 11,000 miles use next sample.
Current/ Unv Avg
ALUMINUM 2 3
CHROMIUM 1 1
IRON 6 8
COPPER 2 3
LEAD 0 1
TIN 0 1
MOLYBDENUM 48 87
NICKEL 0 0
MANGANESE 0 2
SILVER 0 0
TITANIUM 0 0
POTASSIUM 0 1
BORON 33 62
SILICON 15 11
SODIUM 6 15
CALCIUM 1788 2427
MAGNESIUM 127 64
PHOSPHORUS 723 737
ZINC 848 879
BARIUM 0 0
SUS @ 210 ºF 59.2
FLASHPOINT ºF 375
FUEL % INSOLUBLES % 0.4
TBN 2.4
With this OCI, I also added 4 oz of Militec 1. I am very surprised to see the viscosity to be so low with the T&SUV mixed in. I would expect the 68 range. The gas mileage stayed pretty much the same ~25 mpg. I am happy with the results, but my only concern is the viscosity. Could the lab be mistaken? I am running the exact same mix in the car right now. I might do another analysis in 10K to see if the results are similar. Feedback is welcome.
Current/ Unv Avg
ALUMINUM 2 3
CHROMIUM 1 1
IRON 6 8
COPPER 2 3
LEAD 0 1
TIN 0 1
MOLYBDENUM 48 87
NICKEL 0 0
MANGANESE 0 2
SILVER 0 0
TITANIUM 0 0
POTASSIUM 0 1
BORON 33 62
SILICON 15 11
SODIUM 6 15
CALCIUM 1788 2427
MAGNESIUM 127 64
PHOSPHORUS 723 737
ZINC 848 879
BARIUM 0 0
SUS @ 210 ºF 59.2
FLASHPOINT ºF 375
TBN 2.4
