Hi Guys, so we did almost all front suspension work on 2003 Honda Civic with ~145k miles this weekend.
Looked at brake pads and they were looking a bit low. This is the second set of advance auto front brake pads gone in last 25-30k miles.
Also, one brake pin on each side is seized up and rubber boot seems a bit torn too. Also, noticed a lot of rust in brake caliper piston circular hole(which compresses pads against rotors for braking).
Few questions:
1- Which pads should I get which can last a bit? Also, should I replace rotors too, they seem fine though? I believe they are 'Original' ones.
2-What's the best way to unfreeze that pin - I'll use sil-glyde moving forward.
3- Rear brakes are drum ones, do they go bad easily or no? I don't use hard braking or do any crazy driving. Under normal driving conditions, should they be looked at or replaced?
4- Is rust normal inside the piston or no?
Thanks a lot for all of your inputs and help.
Few questions:
