I am the owner of a 2002 Honda Accord V6 with Automatic transmission. Car was purchased with 85K miles and transmission was working perfect at time of purchase. All fluids changed after purchase, and transmission fluid was changed with ATF-Z1 through a cooler-line dump, 2 quarts at a time for a total of 8 quarts.
At 93K miles, it started to shift hard and shift points got unpredictable and often delayed. I added a bottle of Lubegard red and inline Magnefine filter, and shift points returned to somewhat normal, but shifting was still too harsh.
This is a 6th gen transmission so I expected a failure soon, and decided to play around with different fluids. Most fluids I tested did NOT work better than ATF-Z1, until I got this combination.
Currently using 67% Valvoline ATF+4 and 33% Valvoline MaxLife DEX/MERC ATF.
This combination has been in my transmission for 7K miles and is working PERFECT. Shifts are very predictable and soft, as good as my wife’s 2004 Toyota Sienna. With light throttle it shifts almost un-noticeable, and at medium throttle it shifts very nice and precise. Down-shift at throttle increase is perfect with perfect RPM match for clutch engagement. Car now has 107K miles.
This evening I decided to remove the magnetic plug to check for metal, and found NOTHING on the magnet, and fluid looked perfect so I installed the plug and poured the ATF back in the transmission.
It might only work like this in my transmission, but it is worth trying if you have similar problems I had.
Any comments would be appreciated.
