Hi there!
I've a 95 C180 Mercedes-Benz (chassis w202) with a 4 speed automatic transmission (MB 722.4). I bought the car 2 month ago with 106k miles. First thing I did, was to do a ATF change (incl. filter). The old fluid was pretty nasty (brown in color) and there was a slight "mud" on the pan. The transmission had some lag when shifting from 2nd to 3rd, but once it changed gear, it was smooth.
I cleaned everything, changed the filter, and used Mercon V. Shift quality was much improved and the shift lag from 2nd to 3rd was gone. Even so, the shifting isn't perfect. At light throttle and full throttle the changes really good. Only issues I feel are:
- The shift point at full throttle is kind of low (between 5400 and 5500 rpm)
- Shift quality at around 1/2 or 3/4 of throttle isn't perfect. I feel some slippage.
Any thoughts? Could it be the Mercon V? or maybe is just a tired transmission?
I was thinking in trying Mopar ATF4+. Since Chrysler uses some MB transmissions, maybe their fluid is better suited.
Thanks in advance!
Thanks in advance!
