Hi everyone,
When i got my 1998 Mercedes W202 with 128 000 kms i found the shifts to be really hard and slow when cold (1st, 2nd and reverse) so i went ahead and changed the oil with some MB 235.10 75W80 (i think it was the factory fill and what was in there) and that did not really cure the issue.
I just replaced the oil again 4 months and 15 000 kms later with some MB 236.6 ATF and it's like night and day when cold but harder to shift when hot.
What i dont understand is that fot the 717.4 transmission the specified fluid is ATF up to serial n° 7 340 240 and then 75W80 starting at serial n° 7 340 241 (mine).
What did they change in the transmission itself to recommend gear oil instead of ATF ? What am i risking ? I vaguely remember talking about this issue with a mechanic at the MB dealer and he told me they would fill transmissions with ATF if customers complained about shifting problems when cold, even on more recent 6 speed gearboxes.
I'm thinking about trying other 75W80 gear oils since i am not satisfied with the way it feels when hot, what would you recommend ? I'm not going to stick to MB 235.10 approved oils since there's only 2 or 3 oils available. I can get my hands on Total Gear 8, Motul Motylgear, Castrol Syntrans, Shell Spirax, Fuchs Titan Sintofluid...
Should i avoid GL-5 for shifting comfort ?
