Honda 1.5L Turbo Reliability?
Thank you for all the feedback.
I wanted the type of long term reliability that people are used to seeing with Japanese cars with this next purchase and I’m thinking the best bet would be to stick with a naturally aspirated engine instead of a turbo.
Unfortunately a lot of the Hondas have switched to turbos. I’m still not sure about the hybrids. I see Toyota and Mazda still sell cars with naturally aspirated engines.
Curious what people’s opinions are of Mazda? Specifically the CX-5 2.5l, cx-50 2.5l, and Mazda 3 2.5l? They seem to depreciate a lot more than the Honda and Toyota which makes it nice for a certified pre owned purchase, but curious how they compare in terms of quality reliability. Same tier, or completely different group?
The hybrid CRV is naturally aspirated. You can get a sport hybrid for about mid 30ks.. My Daughter has the Sport Touring Hybrid and is getting 37 mpg in local driving. The fuel savings are worth looking into as they have had a hybrid for a few years and seem to be reliable.
as long as you dont chip or tune the 1.5T it should be reliable. They do have some head gasket blowing issues. I am not sure if that has been addressed
- looking at purchasing a 2024 Honda Accord with the 1.5L turbo engine
Do you own one? What problems have you had? How many miles are on the vehicle? Would you purchase one if the goal was reliability?
Recommend w/the usual disclaimers....
So far---4 years, 80,000 miles on a 2020 CRV with a 1.5L turbo. That CR-V replaced an owned-since-new 2009 CR-V with 299,000 miles (which got sold to our mechanic). Also had an owned-since-new 2004 Accord that lasted 18 years and 180,000 miles before being sold to a family friend.
Oil changes when the minder is at 30% to 40% (4 to 5,000 miles?). CVT fluid changes at the interval in the manual.
Never stranded, 1 unscheduled visit to the shop (excluding a flat tire). High-pressure fuel pump failed at 75,000 miles, causing the limp-mode for the 15-mile drive home. Supposedly failure of the Honda high-pressure pump is somewhat common, but an easy repair. Replaced w/another OEM fuel pump for $800-ish.
The leather seats and interior still looks new, no rips or creases. You may/may not like Honda's infotainment system, if that's important to you.
One annoying thing about the 1.5L...it never warms up in extreme cold while idling, even after all the factory software updates. Want the coolant temp to rise and heat to flow? ...start driving after 5 - 7 min.
If its small size is not an issue, also look at the Mazda CX-5. 6-speed auto, 2.5L 4-cylinder, made in Japan, simple electronics (by today's standards), and they removed the cylinder deactivation for 2024 (if I remember correctly).
Good luck.
We owned a 1.5T 6MT in an 18 civic. Loved the motor. We did see some evidence of it “making oil” for the first 2 years of ownership. We changed it just whenever the OLM went off, or maybe early once or twice, but always either mixed in a little heavier oil, same brand, or at some point went to a 5-30. My son drove it hard at times. It made wonderful torque down low, was as smooth as a sewing machine at upper revs, and returned incredible gas mileage. Never missed a beat. We owned it for 4-5 years until he traded for something bigger. I’d own another, no question. With all of the concerns about fuel dilution, my preference would be to pick one up earlier in its life so that it gets moved to a slightly thicker oil sooner, but that’s just me being careful.
Don’t you mean 5-7 seconds? Nobody needs to be idling for 5-7 minutes unless the windows are completely fogged up. Otherwise start and go. Even when it has been -30 degrees here I will still start moving right away. That’s always going to be the quickest way to get the coolant up to temperature.
The motor is so tiny it probably doesn’t burn enough fuel to get warm. We’d just start and go. And here’s the thing - it’s so small, heat came on pretty quickly once it was doing something.
