I buy the orange colored Peak brand "All-In-One" at Napa with the -30 F rating. Then I remove a few ounces from each container and add some full strength 409 from the white and blue bottles. Then shake it to see that it will foam up on top to confirm that it has enough 409 in it. If it does not foam up some, I add more 409 until it does. The 409 will really cut through oil if you get splashed with a puddle that has some oil in it. It is really good stuff. Cleans well and leaves no streaks if the wipers are decent. The 409 sometimes has a slightly noticeable smell, but it is not that bad, and does not last long. Usually I do not even smell it, but every once in a while when I use the wiper fluid I can smell it.
