I have purchased a new 2025 Mazda Miata with the 2.0 Skyactive G 4 2026 Subaru Outback with the non turbo 4 cylinder engine. I guess being retired give me more time to go down various rabbit holes, and the Mazda Subaru lube system offers a couple.
Everyone is aware thatMazda Subaru has a higher OFPB setting than the industry standard. I have never designed an engine in my life so I will blindly accept the Mazda Subaru engine folks have a reason.
I plan on doing 5K oil changes. I will be using the Purolator One filter as it has the specified oil bypass pressure. I will also be running Castrol Edge 0w-20.
From what I have seen, the Purolator One does a better job at filtering but as a result has higher PD across the filter. I have no idea the fluid volume the oil pump would put out at higher RPM's but could see it bumping up against the PD and going into filter bypass.
The Purolator Boss has less PD but does not filter as well. It's not a likely to hit the bypass pressure setting as easily as the One but will be allowing more of the finer particles through.
So, do I go with the One and just accept that it will go into bypass more frequently but when it does the bypassing fluid is cleaner than what the Boss may be doing on a regular basis?
Of do I just need to chill and not chase rabbits?
OK, just realized that the higher than normal bypass is actually on my wife's new Subaru....this rabbit hole too too many turns.
Need more coffee.
Need more coffee.
