as of right now, It is just a Daily driver. I would love to get on a road coarse with it sometime though! The amsoil dominator, souds real nice. That is what I was looking for, a special oil for alcohol. But, I checked out the amsoil web site and I don't see anything about it being special for alcohol.
Here is a little more to the story.
I had the engine together and installed this spring. I bought the short block slightly used online. After getting it together and starting it, with rough tuning, then driving 500 miles. There was metal in the oil. So I go another 1000 miles and change it again. There is metal again in the oil. So I put a pressure gauge on it. It says it has plenty of pressure. So I go another 1500 miles or so. Then check the oil again. There is still metal. So at this point, I decide to take the engine out and take it to a machine shop. The one I used to have my head work done initially. After tearing it down, there is only some minor bearing wear. The guy there says it is from using too thin of oil. I was using 5-30 mobil one! If there was any problem with the oil, I would say, is was from fuel dilution, from running way too stinking rich. I will be getting the engine back in a couple days, and need to decide what to put in it.
