Do you monitor oil temperature? I am curious how hot the oil gets under load.
Originally Posted By: DannyB
Well...Ive done my due diligence, as much as possible. Searched, called, and searched some more. So now Im asking the experts.
Being new to "understanding oil" the way most of you do, I just need a little push in the right direction.
I have read sooo many threads of: "modular motors have to tight a tolerances to take anything over 5w20" to, "I personally run a 40 weight oil and its fine."
I know Ford recommends 5w20, but the ausie versions are specked with 5w30. Pretty sure this was just for CAFE reasons.
Regardless, here is the info on my car, what is currently in it, and what Im thinking of running from the info I could find?...
2003 Ford Cobra
5.1 Stroker
2.8 Kenne Bell
36k on car
Approx. 10k miles on motor
Makes 630hp on low boost/pump gas. Conservative tune.
I do "baby" the car, but enjoy the spirited driving every so often....how can you not with that power on tap?
CURRENTLY has 15w40 Rotella T. (Recommended by unknown shop. Was told this by previous owner. Motor was not built by me)
Now, I live in Oklahoma and the temps are pretty warm. Car wont get driven alot when the temps are in the 20-40* range.
On Start-up in the mornings it idles at 90-100 lbs of pressure. Maybe I'm old-school, but that seems HIGH. When fully warmed it idles at ~40. Cruising speed ~60lbs.
I dont know the additives package in the M1 0w40 (couldnt find it), but that is what I was leaning towards, simply based of some others in the same mod/hp range running the same.
Really looking for some good technical info as to whats better for my application, rather then "well this is what I run, and its great". But, If you have a similar car/mods, please do share what you run!
Thanks in advance!!
I have readily available access to (amsoil, RP, and most brands carried by typical part stores)
2003 Ford Cobra
5.1 Stroker
2.8 Kenne Bell
36k on car
Thanks in advance!!
