High Zinc motor oil in mower
I have several gallons of high zinc Valvoline oil left over from my old British cars that I sold. Would it be safe to use in my JD Gator and Ariens mower since they don’t have catalytic converters? Both have Kawasaki engines.
Use it and report back, there are other things besides oil that you should look at. JMO
Some of these prior threads may be helpful:
I've been running VR1 in my Honda lawnmower and Pressure Washer for years. Friend at advance had two cases of it that weren't moving or something and they were going to just throw it away. Seems to work fine in them!
I do need to jump in here, because we get these so-called Threads about high Zinc Oil in Mowers, I am a high zinc guy. I will stick with my high Zinc Issue, but there are more important things:
1) Check the oil before mowing
2) Blow the Mower off after each use
3) Use Top Tier Gasoline
4) Use a tad of Redline Fuel System Cleaner once a year
5) Use either MMO or tcw-3 as a fuel additive to keep the Carburetor doing great
You can forget about Number 3, 4, and 5, that is your choice, but do not forget about Number 1 and 2!
Let's jump on Number 2 and why this is so important, if you have an air-cooled engine it does not matter what oil you are using if the Cooling Fins get clogged up.
Let me go on another tangent, this has nothing to do with Zinc, if you mow your yard with temps above 90 Degrees Fahrenheit, use either 5W-40 or 10W-40, do not even use 10W-30. The 10W-40 will hold up as well as a 15W-40.
Let's get more technical, you can get a thermal probe thermometer and check your lawnmowers oil temp after you are done mowing, anything below 250F a 40 Weight oil is fine, anything higher a 50 Weight oil is better.
Another tangent, my mower has the engine in front, but if you have rear mounted engine, like a Zero Turn Mower, you need a 50 Weight oil, rear engine mounted mowers run hotter.
I am using HPL CK-4 10W-40 in my Kohler 7000 series engine and it seems to be better with oil temps and no oil consumption versus Shell Rotella 10W-30
Thanks for advice. I only use alcohol free fuel in my mowers. Using redline in my Saab cars and Toyota truck will now include mowers.
Use it with confidence in those small engines. Long life in small engines comes from oil levels being OK, oil changes regularly and air filter maintenance. Air filter maintenance is more overlooked than oil changes and important as most OPE and SxS lives in a dusty environment.
Small engines are so forgiving. Changing the oil at the proper intervals is much more important than the oil you use. There's no need to add anything to the oil.
Yep, my Kohler will be 3 years old in January - and it’s seen 4 different oils in 6 changes - Currently Mobil 1 Extended Performance 10w30.
I believe that Kawasaki uses an iron cylinder sleeve, which is good for long life, but many yard equipment engines run the piston right on the aluminum engine case. And maybe I'm wrong, but it seems to me that a goodly shot of ZDDP for such engines is a good thing to reduce wear. If I had VR1 I'd gladly use it. I've got a bottle of Delvac Extreme 10W-30 I'm using.
I've got a Kohler Command on a commercial walk behind mower that has about a million hours using, I'm sure, the cheapest automotive 10w-30 available. They don't need anything special except for clean-ish oil and air filters as was mentioned.
Still starts on the first or second pull.
