I have a 2007 v6 4runner with 150k miles. I drive 80mph on the highway daily for about 50 miles a day. Can driving at this high of a speed be detrimental? If so, what do I need to pay attention to?
No, Keep good tires on it!!!Can driving at this high of a speed be detrimental?
A Ford Super Duty doing 95I have a 2007 v6 4runner with 150k miles. I drive 80mph on the highway daily for about 50 miles a day. Can driving at this high of a speed be detrimental? If so, what do I need to pay attention to?
80 mph is not fast. That's only around 4,000 RPM in most modern engines.I have a 2007 v6 4runner with 150k miles. I drive 80mph on the highway daily for about 50 miles a day. Can driving at this high of a speed be detrimental? If so, what do I need to pay attention to?
The 2007 still spec'd 30 grade so you shouldn't need anything thicker, and technically within the original guidelines there isn't any thicker oil you can put in it since it has to be ILSAC oil, although since the warranty is up and it doesn't matter what exactly you put in there Mobil 1 0w40 may be a good choice.Don't think so.
However the manual for my 2015 says something to the affect of, "a thicker oil may be required for towing, mountainous terrain or sustained high speeds" which seems to indicate that going up a grade is ok.
I hope not because I regularly do that and have even been guilty of 90-100mph at times.I have a 2007 v6 4runner with 150k miles. I drive 80mph on the highway daily for about 50 miles a day. Can driving at this high of a speed be detrimental? If so, what do I need to pay attention to?
4000RPM @ 80MPH??? Wow. What rear gear do you have???80 mph is not fast. That's only around 4,000 RPM in most modern engines.
I’m wondering the same… both my truck and van turning turning right around 2,000rpm at 80.4000RPM @ 80MPH??? Wow. What rear gear do you have???
No! In fact imo it is probably the best conditions to run an engine under. My only concern would be having good tires, brakes, suspension, and front end.I have a 2007 v6 4runner with 150k miles. I drive 80mph on the highway daily for about 50 miles a day. Can driving at this high of a speed be detrimental? If so, what do I need to pay attention to?
Realize folks there are places like Utah that has an 80 MPH speed limit
The road lol.I have a 2007 v6 4runner with 150k miles. I drive 80mph on the highway daily for about 50 miles a day. Can driving at this high of a speed be detrimental? If so, what do I need to pay attention to?
I take the Taconic and Sprain Brook everyday for work. You'll get passed doing 80.Those of you know the 55mph Taconic State Parkway in NY .... 80mph is called the morning commute.
