Originally Posted By: LeakySeals
What is your mileage? You stated no consumption, any oil leaks?
I like and use M1 HM because its a HM oil and M1 full synthetic. Best of both. Holds up to extended intervals. I use it to help with consumption and leaks, not because of the mileage. I would not use a HM oil if I didn't have to. I think today's modern synthetics (most of them) are excellent for any car, any mileage.
If your having no consumption or leak issues, a good synthetic like Pennzoil Ultra would be a good choice over a HM IMO.
If its the one in your signature however, man thats an oldie, maybe M1 HM would be a good idea. If you have not been using synthetics before, might leak when you switch over. why I like M1 HM, swells the seals shut. In the case of that vehicle, its not the miles, its the age, and what happens to rubber seals over time.
+1
hit the nail on the head here.
If you really don't need HM oil don't put it in. It may prove to be detrimental to the seals. The detergents may be strong enough to dislodge old accumulations and clog up oil galleries etc.
If your oil is working now why change? Also as mentioned don't suddenly change from mineral to sythetic, this can cause all sorts of issues on older engines.
Mine is an 88 boxer but I recently rebuilt it, clean enough to eat off inside before putting it back together. Mineral to break it in and then synthetic but a thick one due to an old crankshaft. Wasn't any need for a HM oil.
