I've done some searching, but have yet to come up with an answer, so here is my rambling question...
I have a 2001 Mazda 626 with the Mazda KL 2.5 liter DOHC V6. It has a solid lifter pack, so no HLA's to worry about. However the valve train is somewhat noisey and seems to be particularly picky about what kind of oil i use.
So far somewhat 'beefy' 5w30's seem to work best. Havoline 5w30 was a favorite and kept the valve train area silent. Castrol GTX and Motorcraft are also pretty decent. However a switch to a 10w30 brings about much more valve train area noise for some unknown reason. I believe it may have to do with the friction gear, making noise as a result of a change in oil pressure, or perhaps a lack of oil, or too much oil pressure at idle. If that is the case, the noise is cosmetic and only serves to irritate me, but i still prefer a completely silent engine.
Now that Havoline has gone on a diet, i'm looking at experimenting with some of the "High Mileage" oils, as they are a good way to achieve a beefy 5w30. Would there be any problems with using a high mileage oil (Like Maxlife or GTX HM) in a 2001 car with only 54000 miles? Are these nothing more than "SL" rated oils with something extra for seal conditioning? and will SL rated oils perhaps be better for engines designed with them in mind regardless of mileage?
My question somewhat stems from my noticing the valve train noise much more in the past year, along with my using only SM rated oils, not the SL rated ones the car was born and lived it's childhood on. Of course it could be age, but other than the bothersome drone/light knock at idle when using some 10w30's, the engine is perfect inside and out.
Engine uses no oil, appears to have zero signs of sludge or even varnish, properly operating PCV, and runds great. The noise i hear is a very slight drone/knock that is cyclical in nature and occurs only at idle, usually when the engine is warm.
Another thought is that the beefy 5w30's the engine seems to like are actually thicker at operating temp, so perhaps ironically 10w30's are too thin? A beefy 5w30 being somewhat thicker at operating temps than some 5w30's.
Thus far I've found the following:
Quakerstate 10w30 = noise
Pennzoil 10w30 = no noise
Pennzoil 5w30 = no noise
Castrol GTX 10w30 = slight noise
Castrol GTX 5w30 = no noise
Motrocraft 10w30 = slight noise
Motorcraft 5w30 = no noise
Havoline (old) 10w30 = slight noise
Havoline (old) 5w30 = no noise
I've used both OEM and WIX filters and cant tell any difference regarding noise.
FYI, the car owners manual recommends 10w30 above -13*F and 5w30 below 98*F. However Ford issued a TSB on the same engine in the Probe calling for 5w30 year round regardless of outside temp. Mazda seems to be sticking with the orig specs, yet the mazda dealer only uses 5w30.
Ideas? I'm guessing most folks will recommend not worrying about using 5w30 through the hottest of summer temps in Texas?
