Unfortunate for sure. I hope i dont have that happenThe one of ours that packed it in went from quiet to chirping. The crazy part was that the chirp was faint, and very intermittent, and when it wasn't chirping, it was dead quiet still![]()
Over on RAM Forum, the common thread between air suspension being troublesome is usually the fact that service techs have no idea how to actually debug the system. They just replace (expensive) parts and hope for the best.
There is a computer module specifically for air suspension that techs seem to not bother checking the codes and/or live data from. A lot of the problems can be traced down to exact issue (height sensors, pressure sensors, etc) but instead they call for expensive compressor and/or valve replacements
What was the Mobil 1 oil that you were running? Was it the Euro spec? Not sure that we have that here in Dubai.2016 RAM 1500 5.7L HEMI - 45K miles. Ours ran on Mobil 1 FS 0W-40 for most of its life with 5K to 7K OCIs.
There’s one guy on there that acts like the Ram expert, thankfully he got banned here.Where are you located?
Im looking for another oil to try in my Hemi. Cant find Rotella Gas/Truck locally anymore (nor the T6 equivalent), reading on these forums vs the RAM forum makes my head spin...its like total opposites, but the gigantic RAM forum thread is turning into marketing lol
I've experienced the dreaded tick 3 times in two different trucks. On both I've changed the lifters and one engine rebuilds. After the first rebuild, I told my mechanic to use Red Line. He was skeptical, being someone who preferred to use the factory oil. On using it, he called me told me how smooth the engine sounded compared to the prior Mopar 5W30 that was in it. Since then I was convinced that Red Line was the oil I would use. When I got my second truck, I bought it used and had a small tick. You had to listen for it, but it was there. I ran with Red Line 5W30 and it went away. The engine was smooth with over 250,000 kms on the clock. Then when Red Line 5W30 was out of stock, I tried AMSOIL Signature Series 5w30 and after about a couple of weeks the slight tick started again. I wasn't sure what kind of tick, eventually the diagnosis was that both the manifold bolts as well as the lifters failed. Did a rebuild with replacing only the lifters that failed and then tried Castrol Magnatec. I wanted to find an oil that I could use when Red Line was not available. It was smooth for a bit and then the tick came back. Tried another thicker oil.. got even worse. Had to do a rebuild again and replace all the lifters this time and then put in Red Line. Engine was back to smooth running.
Now, Red Line is out of stock again here in Dubai and I prefer to keep the OCIs to 5000kms. If I'm going to buy high end oils, I'm going to get Red Line. Nothing else.
Since there is no stock, What else can I use?
I'm thinking of either:
Shell Helix Ultra 0W40 /5w30
Mobil 1 FS 0W40
Castrol Edge 5W30 / 0W40
Mopar 5W30
Mopar 0W40
No, because it's not an approval. The Chrysler Material Standard mirrors API and ILSAC mostly. To illustrate how stupid it is, picture this: Chrysler has a Las Vegas Taxi Trial, or had, I don't know for sure, for MS 6395. Well, all taxi cabs, without exception, have Pentastar V6 engines. Yet MS 6395 is recommended for the 5.7 HEMI, yet not for the 6.4, in spite of the fact that both engines have the exact same tolerances and share many of the same parts. In other words, use what you really think is right for your Chrysler engine, and ignore the useless Material Standard.What about using an oil that meets the Chrysler spec? Is that important?
So.... Mobil 1 5W-40 is good to go in my 5.7 HEMI for the hot Summer, and 5w30 for the cooler Winters out here?No, because it's not an approval. The Chrysler Material Standard mirrors API and ILSAC mostly. To illustrate how stupid it is, picture this: Chrysler has a Las Vegas Taxi Trial, or had, I don't know for sure, for MS 6395. Well, all taxi cabs, without exception, have Pentastar V6 engines. Yet MS 6395 is recommended for the 5.7 HEMI, yet not for the 6.4, in spite of the fact that both engines have the exact same tolerances and share many of the same parts. In other words, use what you really think is right for your Chrysler engine, and ignore the useless Material Standard.
You can run Mobil 1 FS 0W-40 year-round, just like I do. NC is not that hot either all year. I even swapped out the thermostat for a Mishimoto 180F racing t-stat and removed eight out of twelve grille shutters. It makes things run cooler for sure, but the cooling system has its limitations. Of course, I never see 240~245F oil and coolant temps while towing in summer.So.... Mobil 1 5W-40 is good to go in my 5.7 HEMI for the hot Summer, and 5w30 for the cooler Winters out here?
That's low - 280-290F is commonly being reported on the Gen 5 Ram's while towing.Of course, I never see 240~245F oil and coolant temps while towing in summer.
Get one of these: https://www.amazon.com/gp/product/B00EDZD5BOThat's low - 280-290F is commonly being reported on the Gen 5 Ram's while towing.
I have personally seen over 250F just from highway driving in mountainous terrain.
2005 perhaps? Magnums only made 2005 to 2008I had a 2015 Dodge Magnum (wagon) with the 5.7. It had 105,000 miles on it when I traded it on a 392 Challenger. I ran headers, cat back exhaust and a tune. I used mostly Motorcraft 5W-20 and I drove it hard. It still ran perfect when I traded it.
If you are going through multiple sets of lifters you've got something else going on like they aren't adequately cleaning the engine (that's why the engine is normally replaced, rather than the cam and lifters swapped) or the parts are counterfeit.What was the Mobil 1 oil that you were running? Was it the Euro spec? Not sure that we have that here in Dubai.
Mobil 1 FS 0W40
Mopar 5W30
Mopar 0W40
Whoops, key stroke error (more like a brain short circuit)! Yes a 2005 Magnum.2005 perhaps? Magnums only made 2005 to 2008
