High milage oils: valid or gimmick?
Maryland, USA
Today I saw Pennzoil Platinum High Mileage at Walmart. 5w30 and recommended for 75k+ miles. Just like every other high mileage oil I have ever seen. So it got me thinking, is there an actual benefit to using these oils post 75k or is it just a marketing gimmick? Does anyone know what, if anything sets them apart from their non-high mileage counterparts?
High Mileage oils serve a purpose if you have car that leaks or consumes oil. In some instances a High Mileage oil can help. Having said that if your car doesn't leak or burn oil there is no reason to use a High Mileage oil, even if you have high miles on the car.
Typically but not always they're formulated a little more on the thicker side of the grade. Formulation is slightly different with more agents for helping with older seals that might be leaking, and they might clean a bit better.
I'm pretty sure high mileage oil means it can last something like 10,000 miles or whatever they claim... not that you use it on vehicles with a big number on the odometer
No, they are geared toward vehicles with high mileage on them.
MaxLife was the only High Mileage oil I thought behaved differently in an engine, regarding consumption reduction.
You would be wrong.
Not really. An oil like Mobil 1 Extended Performance which isn't a High Mileage oil was formulated for longer OCI's, like 1 year or 15K miles. High Mileage oils were formulated for what I mentioned.
Yes there is a benefit because they tweak the additive package over regular conventional to have extra seal conditioners and detergents sometimes even extra AW Additives, so for a small price increase you get a more premium product.
Pennzoil Platinum High Mileage is thinner than PP and PUP of the same grades.
super-s worked well in our Tahoe. Went from a qt in1200 to 4000
My car is with around 50.000 miles on the clock and I used Valvoline MaxLife on my last change because the Valvoline MaxLife was on sale for cheaper than the same weight DuraBlend I was planning to buy, so I bought the Valvoline MaxLife to give it a try as I never had used High Mileage oils before.
So far so good. The engine is still without any leak, but as this car is 18yo, it's nice to know I am at least using an oil with seal conditioners. There's too many seals and gaskets in that engine ready to get dry, so any help to delay it even more is welcome.
People who keep their cars through high miles save significant sums of money by not buying new vehicles.
High mileage oils were specially designed for this market, to scrub the accumulated excess cash from these people's clenched fists.
I've had a lot of high mileage vehicles (200k +), and never used one. I'm sure they may have some benefits, but the 75k part is marketing. I put 75k on a car in 2-3 years so I don't consider that high mileage.
One or two dollars at a time.
Wonder how many people have thought this before and went way past a reasonable interval.
The EP (extended performance) oils tend to have a higher TBN for longer OCI.
The High Milage oils, refers to older cars with more miles on them. They tend to have more zinc, seal conditioners and be thicker (but not always all three).
Mobil 1_Product_specs
Plain Mobil 1 5w30 has 900 ppm zinc and a HTHS of 3.1
High Mileage Mobil 1 5w30 has 1100ppm zinc and a HTHS of 3.3
(Zinc is from the link above, HTHS is from the Mobil 1 web page)
We don't get them here, but I think the USA has some very nice High Mileage oils.
That's exactly why I said "typically."
If you look at Mobil 1 it is the opposite, and their High Mileage oils are thicker than their regular oils.
That Pennzoil Platinum High Mileage oil looks like a real nice oil.
I am just amazed that someone actually saw Pennzoil Platinum High Mileage in their local store and was able to purchase it! Just like PPU and the Lochness Monster...only seen by a few!
I've seen it in Auto Zone and Walmart believe it or not. PUP OTOH is never on the shelves around here though. I buy it online from Walmart.
