High milage car oil recommendation
Turkey
hi,
i have 110k miles ford in good condition with LPG
im so confused now, i would be glad if you experts can illuminate me.
now using 5w-40 castrol edge full synthetic
but its decreasing fast, after 2000km about 1LT decreased
my city never drop blow -10
am i need to use 5w ? 10w will be enough fluid first start
i want to use 10w-40 but its hard to find full syntetic ones.
i heard liqui moli one of the best arond here
here is my options;
this says synthetictech, it means between semi synthetic and full synthetic ?
http://www.liqui-moly.de/liquimoly/produktdb.nsf/id/en_1300.html?Opendocument&land=GB
this one semi synt
http://www.liqui-moly.de/liquimoly/produktdb.nsf/id/en_1091.html?Opendocument&land=GB
and motul, semi or full synthetic i couldnt realize
https://www.motul.com/tr/tr/products/oils-lubricants/6100-synergie-10w40
please help to chose,
10w is enough protection no more -10 degrees and 40w is enough for max 40C climate with LPG ??
and which brand you recommended me
thanks a lot
Greetings from Turkey.
Doğan.
1 liter of oil in 2,000km is very fast consumption. I would have the car inspected to find out why it is using oil so quickly. Switching to a different oil is only a temporary solution to a larger problem.
I don't consider your car to have high mileage. Some might, but nearly all of my cars have far more...none of them "burn" any oil, but they do use some. E.G. I add nothing to the Corolla or S600, and I might add 1 QT per 5,000 miles in the Volvos...more in the Toyota 4 Runner...closer to what you're adding, but it has over 250,000 miles on it.
The oil consumption is a little high for your car's mileage, but most manufacturers won't consider a warranty claim until it's using 1 liter in 1,000KM...so, personally, I would just keep buying whatever meets spec for your car, and is reasonably available (both cost and in stock). 5W40 is a good all season choice.
i have 92 ford taunus which produced in Turkey and last.
2.0 ford pinto engine with weber carb.
my city never drops below -10 and never goes up more than 40C in summer
i will replace real soon but i cant decided yet.
should i go with motul or liqui moly for 10w-40 grade
i think 5w not necessary because as i say my city never ever drop below -10 and i want one step thick stop leakings.
motul 6100 vs liqui moly superleichlauf
maybe 15w40 but no...
my oil info not good enough to make choice so i need your help
