Viscoplus Heavy Duty Formula
This is a viscosity booster, like LOS and such, and is loaded with FM's since the bike warning is applied, so better than LOS. Seems to be marketed to HD market, where sumps are 45 liters. 300ml @ 2K cst is just barely enough to make a small dent, about 27cst over the said 350 if it was to mixed in M1 of your example.
Totally makes sense to use the stuff if your oil shears out of grade, but TBN is healthy. Dumping 50qt of good oil is a lot of money.
