'06 HHR, 184K, 2.4L/auto. Initial behavior was hold 1st too long and shift hard into 2nd, then goes straight from 2nd to 4th - did it pretty much every time. P700? transmission communication DTC. First measure was to check and clean connections, so I unplugged the TCM (with the battery hooked up - maybe I knew better), no real surprises there, but upon hooking it back up, it won't crank. Zilch. Lights burn brightly while key is turned to "start", so it's not a bad connection - no click, no nothing. I suspect the neutral safety switch function is being impeded. Tried resetting with my Snap-on "brick" scanner, but no codes present. With everything hooked back up I unhooked the battery for 30+ minutes, no change.
What's next?
What's next?
