If you haven't refreshed the fluid, now would be a good timeGood info, thanks. The one I got is supposed to be pre-programmed plug and play, so we'll see how that works out.
Check the TPS sweep with live data, make sure it's spot on
Also, according to the TSB, since you'll be putting in a new/different TCM, you must do a Quick Learn to reset CVI values
Keep us updated on how it works out
