HF star socket set
Some of their stuff has gotten much better and some is still junk. I have found their hex and star sockets to be pretty good so far. I used the set linked by the OP for some door striker bolts.
I have dealt with numerous star sockets and I find that only the premium brands get the job done. Generic Chinese ones crack, and cheap ones from the USA get rounded off.
That's a bit different from my experience. I've found that premium brands tend to crack and cheap junk twists. Rounding tends to happen only as a result of camming out because I was too lazy to grind the tip flat before using it for the first time.
Originally Posted By: Donald
They were on sale already. I seldom get to use the coupon as in most cases I buy something that is already on sale.
FWIW - the 20% still applies on sale items unless specifically excluded.
+1
You can use a coupon for items that are on sale, unless the item is one that's specifically excluded from 20% off coupons (compressors, tool boxes, etc.).
But, you can't stack coupons. You can't try to use a sale coupon for an item and then also use a 20% off coupon on the same item.
Before they set up the exclusions for 20% off coupons, you could get the 44" box for only $279 + tax. I paid that price and it was a steal.
I'll be lucky if I use each one of the sizes once before they put me under.
You don't need to use each of those sizes for it to matter, just using one once can make all the difference in the world. That said, it's very likely that even the softest Torx sockets will be fine for most uses if you grind/file/sand the tip flat.
Should you find one of them starts to twist, stop and get a fresh socket. Making a trip out to the store to buy a new socket can take less time than extracting a screw with a boogered up head. A fresh socket and an impact driver may well save you from going through your bag of tricks for extracting stuck bolts.
Originally Posted By: GumbyJarvis
Irony, Company Named Pittsburgh is prolly made in China or Taiwan
Yes the people when they come home say to their spouses, Yeah I was at Pittsburgh again. I need to get to get a job in Chicago.
LOL.
Regards, JC.
Yes, the Taiwan made Pittsburgh sockets are pretty good, but the pliers and screwdrivers at HF are still subpar.
I guess thats an advantage of a local store. You can see where its made and judge the quality.
I have those torx (star bits) and their hex bits. They wre pretty good quality IMO. I rarely use them but I have not had any problems. I was considering buying a nicer set made is USA but I have no complaints with these.
