You have a new engine that you run hard high revs, consumption is going to be a bit high. We currently run 4 v10 tritons in wrecker service and all but 3 are using 5w20. Ford has put millions of dollars into oil research and feels comfortable with 5w20. Any engine when run at high rpms is going to burn more oil than if not, and pulling will cause an increase as well. Let the engine break in and give things time, no 2 engines wear the same. 5w20 will not cause your engine to blow into a million little bits. Our trucks have over 500k combined miles on them without any engine issues, as well as my current personal f150 running which ran 15w40 in south Dakota winters and idling thousands of hours and pulling 10k plus loads for 120k miles. The all burn similar amounts of oil(approx 1.5q) per oc of 5k,, and I run 0w20 in my truck and run great. Your engine might burn a bit as not ever engine is perfect, but I would not deviate for the manual until warranty. Our oldest v10 has 210k on it and now runs 5w30 due to consumption but it is out of warranty. It pulled a loaded semi w/ a 53 foot hopper and pup (over 110000 GVW) 32 miles to our shop while running 5w20 4 years ago.
All this hate twards Xw20 is stupid, it has been speced for 50+ years as straight 20. As long as your trucks manual says that 5w20 is required for your use pulling your loads you are fine, and ford backs that. We run 5w20 in one of our 700+ drag cars that has a ton of passes with a 200 shot of nitrous and has around 18k road mile and it has amazing oil pressure. It will not kill your engine as long as it is speced for it. Get some miles on that ford and let us know how it is running!
Sent from my IPhone
Sent from my IPhone
