OVERKILL
$100 Site Donor 2021
Originally Posted By: skyship
Yep, they make a 5/20 and here is the link:
LM 5/20
Too busy to go check specs.
Data sheet:
5/20 DATA SHEET
IS THIS THE CORRECT ENGINE:
FORD E450 2012
Ford USA License plate:
Engine: E-450 6.8 V10 (2008 - ) Date: 7-1-2013
· Capacity : Capacity 5,7 liter
· Use : Normal
· Intervals : Check 1 months
: Change 7500 miles / 6 months
· Products : Top Tec 4600 5W-30
: Leichtlauf High Tech 5W-40
: Longtime High Tech 5W-30
· Use : Severe
: Change 5000 miles / 6 months / 200 hours
It lists that engine as in current production and the above info is from the US page (Under vans) of the Liqui Moly oil finder. The Germans only accept original design spec sheets, so it must be the wrong engine!
OIL FINDER:
LIQUI MOLY (USA) OIL FINDER
Does LM make a 5w20? I couldn't find one on their site
They obviously aren't going to recommend a product they don't make.
And please expand on your last point. My M5 requires an oil that meets LL-01. That covers a wide range of 0w30 to 5w40 lubricants. It isn't a viscosity spec. Ford has their own oil specifications for their gasoline engines that include, 20, 30 and 50 weight oils.
Excellent, didn't see it on the original link you posted when I went through the oil list.
So it is an HC synthetic, recommended for intervals up to 40,000Km.......?
It is also not certified by Ford for the WSS spec's, simply "recommended for", similar language to the boutique American synthetic brands like Royal Purple, AMSOIL, Redline....etc.
Now, earlier you said 5w20 sheers and is inappropriate for extended drains, however they are saying:
Originally Posted By: LM
APPLICATION AREAS Ideal for modern Japanese and American gasoline engines. Particularly suitable in case of long oil change intervals and high motor requirements.
and
Modern premium-class fuel-efficient engine oil, which especially has been developed for the year-round use in Asian and American vehicles. The combination of unconventional base oils on synthesis technology in connection with the latest additives guarantees an engine oil which protects against wear, reduces the oil and fuel consumption, keeps the engine clean and provides for a quick oiling of the engine. According to the instructions of the manufacturer, oil change intervals of up to 40,000 km are realizable.
LM 5/20
Data sheet:
5/20 DATA SHEET
FORD E450 2012
· Use : Normal
· Use : Severe
OIL FINDER:
and
