Hi all. I have a 2016 Honda CR-V EX that I acquired in February of 2020 with 19,877 miles on it then.
Since it spent those miles in the hills of Pittsburgh PA with plenty of stop and go traffic I consider that sever service and therefore did 3 drain and fills of the CVT fluid starting around 25 K miles and driving it about 1 K miles to mix the new with the old before doing each additional drain and fill, because each drain and fill only gets out 1/2 of the fluid that was in it.
Here are some pictures of the CVT fluid I removed each time, and also a withdraw from the top sample of the CVT fluid at 28K miles to see what the CVT fluid looks like after the 3rd drain and fill has mixed with the old, and a virgin sample of the Honda HCF-2 fluid.
The jars are 10oz Polar Peach Slices jars left over from what I bough at Wal-Mart. The flashlight is a StreamLight ProTac 2L-X and it is set to 500 Lumens.
I bought 14 quarts of the Honda HCF-2 fluid from OEMPartSource.com and also a crush washer for the drain bolt and one for the over-flow bolt, and reused the originals twice. I could of got by with only 13 quarts. The amount I had to add to get fluid to come out the over-flow each time was very little. And after 3 drain and fills I still had enough in the remaining open quart to provide the virgin sample. I still have one quart I never opened. And I did have the vehicle perfectly level each time, and ran it in each gear for 10 seconds or more down and up 3 times to get the air out, and also let it sit to get any foam to settle out before doing the additional add until some came out the over-flow.
As you can see, with each drain and fill the CVT fluid becomes less dirty and light can shine further into it.
In the future, I can withdraw a sample and compare it to the existing library of samples to get an idea of the condition of the CVT fluid and how many drain and fill it could use.
There was nothing wrong with the way the CVT was working even just before the first drain and fill, but after 3 drain and fills it does run butter smooth which is a slight improvement and barely a noticeable improvement, because again it was working fine before the first drain and fill. There were some post on the "Honda CR-V Owners Club Forum" where CVTs with 30K or more were having some problems and the owners had to change the fluid several times to get them to work good again. So my 3X drain and fills starting at 25K miles are decent preventive maintance.
