silverrat Joined Jan 9, 2009 Messages 1,798 Aug 10, 2015 #1 Planning on replacing the sunroof glass on my car soon. Can someone please help me interpret this measurement from the service manual?
zrxkawboy Joined Nov 30, 2004 Messages 3,179 Location SD Aug 10, 2015 #2 2+0.5/-1 mm means that a range of 1mm - 2.5mm is acceptable.
S stevejones Joined Feb 13, 2011 Messages 413 Location Midwest Aug 10, 2015 #3 Yep, it means the seal should be proud of the metal slightly all the way around the perimeter...
V Vern_in_IL Joined Jun 25, 2014 Messages 3,434 Location IL Aug 10, 2015 #4 Or easier said in the non-metric world: 1.75 mm +/- .75mm
ZeeOSix $100 site donor 2022 Joined Jul 22, 2010 Messages 40,507 Location PNW Aug 10, 2015 #5 Another way to say it is the top of the rubber seal around the glass should stick up above the roof panel surface between 1.0 and 2.5 mm.
S stevejones Joined Feb 13, 2011 Messages 413 Location Midwest Aug 10, 2015 #6 On second thought given the "precision" nature of the thread title, the dimension really means this: Ideally, get the seal 2mm above the metal. If it isn't; it's OK to be at 2.5 to 1.0 mm above. But we'd really like 2mm nominal.
Yah-Tah-Hey Joined May 26, 2014 Messages 5,693 Location Columbus,Nebraska Aug 10, 2015 #7 +.10 to +.04. I read that as the gap can be as much as .10 or as little as .04 and .08 is preferred.
silverrat Thread starter Joined Jan 9, 2009 Messages 1,798 Aug 11, 2015 #8 Thank you all for the responses
