Perhaps the problem is the types of trips you take.
The next time you take your typical route, count the number of subtantially 90 degree turns you make, then divide that number by the number of miles you drove for that route. Call that turns per mile. Freeway off ramps that loop around back over itself count as 3 turns
For example, when I drive to work, I back out of the driveway (1), turn onto the main drag (2), turn onto the expressway (3), turn at the end of the expressway ramp (4), make a right (5), a left (6), a right (7), a left into the parking lot (8), and a 180 into a parking spot (9 & 10). I drive 10.5 miles TPM = 0.95
I have found that the farther you go away from 1.0, the better (or worse) the tire mileage. This is because most tire wear occurs during cornering.
Needless to say, if you corner hard or accelerate (or brake) while turning, this hurts the tire wear, too. Frequent trips to the corner store, also hurt tire wear (high TPM)
Let all of us know what you get.
