Hi folks:
I have a strange leak that I cannot seem to locate. It appears to be transmission fluid - it is really slow, and doesn't dry and gunk up like oil, and appears to stay wet. (A big clue is that transmission fluid needs to be topped up every year or so).
I don't see a mating surface (such as a transmission pan) where it could be coming from. It seems to be coming down where the motor and transmission meet. I would expect oil to come from this area if the main seal was bad - so I'm wondering if I'm not looking high enough. Google searches have not been helpful - as most folks seem to have oil leaks on the other side of the motor.
The CV axle boot is a bit wet - I figured the boot was bad - but could it be a seal behind the boot? Any tips would be appreciated.
Thanks.
Thanks.
