Heaviest 5w-30 Synthetic?
This is my go-to heavy 5W30 synthetic
Quote
Castrol Edge 5W30 A3/B4 Full Synthetic
It's rated API SL (high ZDDP, but passes all SN tests), ACEA A3/B4, MB 229.5, BMW LL-01 and VW 502/505.
Noack volatility below 10%, Zinc around 1000 ppm, HTHS = 3.6 cP, KV100 = 11.9 cSt, SA = 1.2%, TBN = 10.2 and PP = -45C
Quote
Kind of a blind statement to readers.
What vehicle - what year - what engine?
There's room in your Signature to put it.
Quote
That looks like a super strong oil! SL oils must've had a better and stronger add pack. I remember my SJ RP had a killer add pack via used oil analysis.
Quote
SL is irrelevant. Any API spec. is irrelevant in Euro oils.
Originally Posted by edyvw
Pennzoil pds were always lottery.
Euro L is at most 12.1cst. 5W40 Euro is 12.8cst.
Quote
No it isn't:
a.) 5w30 L 12.63 cst
The lowest recent PDS shows it 12.38. BTW, I told the OP not to use it. No reason to use boutique German oil in a Hyundai either...
You do know oils can thicken during exploitation?
Also, if Pennzoil Platinum Euro L is above 12.5cst and like that being sent to vehicle manufacturer to be approved as 5W30 oil, sample would be returned and not approved.
As for Hyundai, Hyundai itself does not know what oil they recommend to consumers.
Who cares, what does that have to do with anything? I doubt it would be sent back as a C3 oil that is borderline as they know it probably sheers. In any case, if he needs a thicker 5w30 just go with RTG. It's cheap with rebates...
Quote
No it isn't:
I worked on testing of oils that went for approval. Company would get back letter saying: what is wrong with you?
