I did a lot of research on this, so let me know what you think. I have a small block engine in my 1983 Chevrolet El Camino, I put Sanderson Shorty Headers on 2 years ago and had them Jet-Hot Coated, I have the regular starter and the header pipes are maybe 6 inches away from the starter, on a hot day the header pipes are about 400-450 degrees and the starter and solenoid is 165 degrees, this is taken with an infrared gun. I have read that gear reduction starters do not always cure the Hot Start Problems, I read that the starter heat shields and wraps only block 30% of the heat, a company that makes Mean Green Starters, which cost almost $260.00 say that there starters are not affected by heat. The other thing I read is that the culprit to these problems is the solenoid and the only way to combat this is to put on a starter solenoid relocation kit that puts the solenoid away from the heat. The car starts up fine when it is cold but after driving the car on a hot day if I stop for a few minutes and then restart it is like the starter is dragging or slow for a second or two. The guy at Summit told me that there gear reduction starters are only better than the bigger starters because they are smaller and the starter and solenoid is a little bit further from the exhaust, he also stated it would be a good idea to put the wrap on the mini starter. I should also point out that this starter is about 7 or 8 years old. I did clean the battery cables tonite and she started up better after a long drive, the battery is 2 years old and everything charges fine, I can always check the battery. So my options are NAPA starter and solenoid relocation kit with the starter wrap, gear reduction starter with the wrap, or Mean Green Starter for $250.00, I should also point out the NAPA starter and Summit Gear Reduction starter are about the same price, I know I posted before about which starter to buy, but I wanted to go into more detail about my situation and let everyone know what I gathered about hot start problems, another thing with the solenoid relocation kit is that it keeps the small wires further away from the heat, anyone with any experience with this situation who has had headers or is familiar with my situation please chime in. 1 last thing when I say the pipes are about 6 inches away I mean the pipes run above the starter, they are not close like on a full length header.
