Originally Posted By: SecondMonkey
c3po - I'm tellin' ya, just make your own. You'll get something better than you have now, and better than anything Napa stocks. It is so easy. A hunk of cable, two battery terminal connectors, and two ring terminals for the other end to bolt onto the starter and ground points. Very very easy, and you've got everyone here to walk you through it.
I have upgraded the battery cables on every vehicle I have ever owned, and always, ALWAYS, it made a big improvement - even when the old cables still worked.
I did this to avoid paying the ridiculous price that the OEM SAAB part sells for (think $165). My positive terminal stayed corroded on my 900 b/c it was right in the stream of heat from the exhaust manifold as it circulated around the engine. I cleaned corrosion several times but it kept coming back. Matter of fact, when I bought the car used, the cable was corroded into. But $16 worth of cable and about $10 worth of terminals and I was in business. Never corroded again.
